plc and scada interfacing problem
Mar 2015
mumbai
I'm trying to interface plc and scada where scada is monitoring and controlling the parameter using MODBUSA3 protocol but SCADA is not sending 05 function code to write the coil(on/off he coil).I'm using Vijeo Citect Scada 7.2.please help me.
1). Are you writing the correct value?
Statement below is from the Modbus standard:
A value of FF 00 hex requests the output to be ON. A value of 00 00 requests it to be OFF. All other values are illegal and will not affect the output.
2). Does the Modbus connection work otherwise? Does the Scada read data from the PLC?
If the master executes a read, but will not execute a write, then
1) the slave register the master is addressing is not writeable, it is read only
2) The slave register the master is addressing does not exist or is undefined
3) The master is writing an unacceptable value
4) The master does not implement the 05 function code (unlikely)
Is it possible to connect a PC with running WinCC Advanced or Unified to a siemens PLC such as S7-1200 across different subnets? The computers can...
93
Has anyone used Do-More or Productivity PLCs with VTScada? Or Ignition? Which was the easier platform to use?
669
Hello Experts, I would like to know how can a PLC with modbus tcp/ip protocol can communicate with remote scada with modbus tcp/ip over gsm 4g...
1,025
Good Afternoon, I am an intermediate Programmer who has set up for part of my Wastewater plant a Two server redundant WinCC scada system with an...
1,033
Dear all, I have a FX2N-20MR chinese semi-clon of a Mitsubishi PLC. It has only a serial DB9 port that cannot be removed or exchanged (which is...
2,080
