facing problem with wonderware intouch
manish singh
Sep 2013
noida
hi , Friends
I am facing problem with wonderware InTouch in which the tags which are used for alarms is showing the date time of 01/01/1970 5:30 am in Alarm Viewer.If i use the .TimeTime String and .DateTime Dotfield of Tags its shows the date time of 01/01/1601 5:30 am.
IO server is used Triconix DDE server...
I'm not sure what you try to accomplish. Why do you want to use the .TimeDate (I guess .DateTime was a misspelling) and .TimeTimeString? These dotfields holds time data for the last valid data change of the relevant tag in I/O server. Nothing to do with alarms. If you want to read time of alarm for a tag, you may use the .AlarmDate and .AlarmTime dotfields.
Hi Friends, I am facing a problem with encoder adjustment in Sew Electric Cylinder CMS71L. encoder using is Sick Hiperface Drive is MOVIDRIVE...
17
799
I am facing a problem in which when the emergency stop is pressed, the motor comes to zero speed but going to start state instead of stop state...
1,614
Hi everyone, I am facing a problem with my F5 series KEB Frequency drive. I have cobivis5 software and HSP5 service cable for interfacing. i am...
2,105
I'm working in Schneider PLC platform and not aware of RSlogix. In my new project I need to communicate my Quantum PLC with 1756-L55 controller...
1,702
I'm trying to interface plc and scada where scada is monitoring and controlling the parameter using MODBUSA3 protocol but SCADA is not sending 05...
1,702
