Peter Nachtwey
Steve Etter said:Question: Does anyone have a formula or rule-of-thumb for sizing filters for this type of application. I have never had to do this, so I really don't have a clue what to get.
Steve
Yes, 1/(2*PI*R*C) = Cutoff frequency. Where R*C is the time constant. The cutoff frequency should be 5 to 10 times higher than the highest frequency you want to measure. You may reduce the cutoff frequency to remove even more noise but beyond this point it is better to fix the noise problem. The equation allows you to choose R * C. Since the resistor is in series with what ever the input resisteance is, a resistor that is too big will noticeably attenuate the signal. To compensate one usually chooses a big capacitor.
A =-20 log | 1 + jwRC |
