Analog Input sensor to sense rpm
Thanks for all your help...
I will try my best and let you know ...
This is my first application for programming so i was a little bit nervous but i am clear now
if u r familier with microcontroller then programme a microcontroller based counter to read the proximity signal.Then u take read out periodically the rpm by input modules of plc.in this case the mc based system will be dedicated for rpm measurement.
Hi looking to install a smaller less sophisticated PLC for fountain timing and also one analog pressure sensor which would be used to detect...
23
631
I have a Bentley Nevada Velocity sensor that claims to spit out a 100 mv/IPS signal. I'm being told that it will work with an analog input card...
7,084
Hello everybody. for an asignment we are using a s7 1200 siemens starterkit to connect sensores to create a program. we were hoping to save some...
6,599
Hi, I need to read the floor temperature of you refrigerated warehouse. I would like to know if it's possible to send a 4-20mA current over...
3,185
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,251
