Analog input write to HMI
nestbulala
May 2015
Saudi Arabia
Dear Experts,
I have a project that needs to write an analog input value to an HMI that accepts only digital input. The CPU for the HMI is CortexM3. The analog input will be coming from a Sixnet controller using ATMEGA69 CPU and they are communicating through rs232. I should be able to modify a setpoint in the HMI say a temperature and process by the controller to provide a desired output.
Can anyone please guide me on how to go on with this project?
Thanks in advance.
nestbulala:confused:
I'm not familiar with the CortextM3 CPU but generally you don't write to a HMI screen. A HMI displays data which is read from a CPU or it can be used to write data to a CPU. What HMI screen are you using?
Dear beethoven,
I am using HMI from stone technology but has limited application. We should be able to read or write analog signals to a controller as a set-point but this hmi needs a converter to digital signal before it can display analog values. Maybe one solution to this is to make a circuit from a microcontroller like PIC, program it to reflects the set-points and another register to read. Could this be possible?
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,176
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
283
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
132
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
104
Why AMIo800 Analog input module's I/O LED is Lighting up Red? Checked module connections, 4-20ma wires etc but this light is continuously Lighting...
117
