Analog input
medensat
Jul 2015
CASABLANCA
19
Hi guys,
i'm working in a project whose aim is to maintain the temperature between (3 and 7 ° C) and if the temperature exceed these two thresholds an alarm is triggered.
* I want to know how to handle it knowing I program with GX iec developer 7.04.
thank you in advance
Are you using the Fx2N-4AD-PT module? There are ready made Mitsubishi function blocks to do that (you want the AnalogFX_V310 file downloadable from their website). Regarding scaling the values come in as 0-1000 points = 0-100C. There is a help file included in the download that explains the parameters.
I can't post a link as you need to create an account with Mitsubishi and go to their download center. However I have sent you a GX IEC project that I have just built that includes the function block - Check you messages.
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,174
283
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
132
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
104
Why AMIo800 Analog input module's I/O LED is Lighting up Red? Checked module connections, 4-20ma wires etc but this light is continuously Lighting...
116
