Analog Output Simple Problems
budiman
May 2013
Medan
43
Hi All,
I'm new on PLC about Analog Output and Input problems, but i know how it works.
I'm using PLC Omron CJ2-CPU32 with Analog Output Module DA-041
In this program, i got confused why the analog output doesnt work.
Its just a simple program for Analog Output to control VFD, but seems like the analog output doesnt give any signal.
Would you mind to check "Main Program" section on line 21?
First i need to turn on '50.04' to turn on Forward on Inverter Toshiba then i add or reduce the speed on line 22 and 23.
The problem is the analog output doesnt give any signal at all.
Here i attached the program that i have made so far.
I need help from all of you soon.
Thx.
Best Regards,
Budiman Chandra
Hello! Hope you are great. I need to make a change in a PLC with ladder logic. I will mount a analog valve and I need to control it in ramp up...
332
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
91
Hi We're having issues with an FX1N-1DA-BD Analog output module. We're using an metallic contamination sensor MCS 1000 to detect particles. This...
115
261
I have a program that I am gradually piecing together (my first program). There are 4 cascading timers that turn Y001 and Y001 + Y002 on and off...
549
