Analog Output
clarke2006
Mar 2006
Houston
I have a PLC5 processor using an analog output card(4-20ma) to control a mitsubuishi freq drive. I am having trouble writing the code for this. I have two channels as I have two Freq Drives I Want to Control. I understand that I have to use block transfers to do this. Could someone send me a sample program to show how this can be done. I have RsLogix 5 Software. Thanks in advance.
let's do this the easy way ...
please post your existing program - and tell us EXACTLY how your I/O is arranged in the chassis ...
we can't give you a detailed example without knowing whether you're using 2-slot, 1-slot, or half-slot addressing - and which Rack, Group, and Slot your output module is located in - and where you have "spare/unused" integers available ...
Hello! Hope you are great. I need to make a change in a PLC with ladder logic. I will mount a analog valve and I need to control it in ramp up...
339
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
97
Hi We're having issues with an FX1N-1DA-BD Analog output module. We're using an metallic contamination sensor MCS 1000 to detect particles. This...
118
265
I have a program that I am gradually piecing together (my first program). There are 4 cascading timers that turn Y001 and Y001 + Y002 on and off...
552
