Analog Scaling Problem
iamwags
Aug 2012
northern wisconsin
New to programming. How to take Analog Input data (scaled 0-10vdc = 0 to 359 display on PanelView 550 for PLS Readout). I have it working roughly but need better resolution for readout. Problem is small rotational movement equals more than 1 degree on Readout.🔨
I would set it up like the example in the Panelview Demo projects. Note that this gauge range is not 0 to 360 but is -90 degress to +110 degrees. If you need better resolution and your PLC has a Floating Point Data Type ("F8" for RSLogix), then you could change your gauge tag to have a decimal point and tenths of a degree resolution.
PanelView 550 Circular Gauge Setup.jpg PanelView 550 Circular Gauge Change to Floating Point.jpg
You might try scaling the value to 0-3590 in the PLC and the PV . The decimal point would be implied, if that doesn't confuse people.
Hello All!! I am new to the forum and have seen alot of good answers so far, but I have not been able to resolve the issue I am having. :mddr...
4,297
Dear All I am working on the same thing where I have GE fanuc 341 CPU series 90-30. I need to add three analog signal coming as 4-20 mA signal...
4,838
Hi all.m doing my FYP regarding PID control of inverted pendulum.for this first m scaling the analog input of 0-10 volts using AB SLC 5/03,NI8...
2,201
Dear All, I require valuable suggestion for solving below mention problems. I’m using Omron PLC Analog module AD041 for scaling...
11,393
Hello, We monitor the temperature of a pipe via a 4-20mA temperature transducer. This goes into DB135(Read Analog Inputs). The issue I have is the...
638
