Andon Displays
pbaker88
Jul 2013
Victoria
22
Hi all,
Has anyone had any experience with large andon displays for showing production line data. eg. OEE, rate loss, machine status. Which brands are you using and how are you communicating to them?
Maybe big flat screen TV's running as a citect client will be more versatile.
All the facilities that I have been to lately have used flat screens as displays. It allows a lot more flexibility in what you want to display, and you can change it later to fit new process data.
They are generally hooked up to the MES with an Intel compute stick.
Hope that helps!
TV from Walmart and Raspberry Pi.
We have had good luck with the 55” Phillips SmartTVs too. I mention that because most if not all consumer TVs are made to live indoors with conditioned air.
Our place is hot and dusty, and knock on wood, no problems for over a year.
What is the most common size for Andon / Stack Lights? I need to put some on a machine and I am looking that the AB 855 Stuff and they have...
1,351
How to communicate a Production count display (Andon) board via Allen Bradley Compact logix PLC Through serial port. I need Port configuration, 9...
3,489
I need some help with some programming or maybe just another way of looking at attacking this problem. I'm using a Direct Logic D0-06DR for...
2,155
Hello, I have used profibus to communicate CPU-226(Master) with CPU-224(Slave) with TP277PN/DP & ANDON Board.My DI/DO's are 180 so I...
1,120
I have been tasked with outfitting our facility with Andon lights. For those not familur Andon lights are a used in lean mfg. methodology to...
5,812
