another direct logic plc question
Razor89
Jun 2010
ottawa
im using a Direct-logic plc, with DS Launch programing software.
how do i go about triggering the DO outputs on the plc from the device memory table while im online with the programming software???
- forgive me if the question seems simple but im trying to update an existing program and ive never used this brand of plc/software before.
Thanks in advance to the direct-logic experts out there - also do you happen to know of any online manuals for this type of software/plc brand
nick
The online manuals are available here.
To force an output first open a Data View (Debug - Dataview - New). Under 'Element' enter thwe desired output (e.g. Y0). Go to View - Options. Using the DataView tab choose the Display-1 tab. Under Bit Display settingd choose the 'Override Bits' check box.
Back to the DataView window make sure status is on (you see the on/off state in the 'Status' column. Then choose the Edits button. You should now have on/off buttons as well as button to enable or disable the override for each individual itme entered in the 'Element' column. Click the Override then choose On or Off.
Yhis information is in the 'Debugging and Monitoring' chapter in the manual supplied with the software. Information for an older version (32 bit Directsoft) is available online in the QuickStart at the location noted above.
You will need to use either the K-sequence or ECOM protocol for the link. DirectNet protocol is not capable of forcing outputs.
I have one common Buffer DB 10 with multiple String values, I am trying to move from DB10 to MainDB 20 using with SFC 20 Move block not sure how...
1,289
Yes, I did search for information first. Yes I looked through the limited help files that came with my Step 7. No I do not have any other books...
77
21,002
Hi, Here I am in trouble I think, I have many Standard Blocks written in combination of STL and LAD, like following...
9,637
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
152
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
428
