Another rung I do not understand! Mistsubishi FX2
Terminatez
Jan 2015
California
-|x20|---|x3/|--|x0|------------------(m19)
-|m19|-|...................|-|i8013|---------(y16)
This is a rung on ladder program that was printed out for me, where does NO i8013 come from? I can't even input it into GX Dev.
I suspect this may be a misprint - m8013 is a read-only diagnostic device . It flashes at 1 sec. intervals . It is normally used in outputs to indicating lights to make them flash . Without comments it is hard to be sure .
Paul
Oh well - that problem solved .The only thing that puzzles me is how the "m" changed to an "i"
Paul
If you consult the Mitsubishi programming manual and I hope you have one, if you don't get it now, then you will see M8000 onwards are specific devices that have many pre set functions. I too am confused by the I prefix, maybe you have a Japanese version.
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
67
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
191
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
450
Hello I need to message read the entire 16 channel raw analog inputs from a 1769-L33ER Compact Logic controller to another 1769-L33ER Compact...
256
I am noticing a problem where i am using MOV instruction and writing literal text into source and String datatype in destination. It works fines...
499
