another software ??
maintenance said:
Is there any software made by other companies that can program AB SLC 500s?
Why?
The RSLogix 500 package is very affordable, guarunteed to work, and has a nice interface.
Well You can take the Ladder logic File and convert it to a SoftPLC file.
Then you would have to ditch the SLC hardware altogether and build a Soft PLC.
This is probably not what you are looking for.
If you want to use the AB hardware, I think you really want to use the RSLogix software.
Good luck!
As in modicon140CPU43412A installed for wartsilla power plant control, and as i know concept software employed with such plc, but here we have a...
1,265
What software are you using or would recommend for drawing interlock, control and sequence diagrams? A full blown CAD feels over the top to me...
3,235
A client just called and asked about transferring a program from one of their op17 to another. The current one has a 'bad button'.. but they don't...
2,646
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
63
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
180
