Any 4-20mA to Relay converter?
IdealDan
May 2017
MA
480
Hi Friends,
Please I want to know if there is a small module that can convert 4-20mA signal to Relay (discrete) signal?
Thanks in advance
A click plc is nice and cheap and could.do.it. Free software too.
You.would have to calculate and test the proper setting points as well to trigger the relay. There are some devices other there though too. Let me dig one up
Search for a “set point relay”. That’s what they do, you create a set point on the range of the analog signal st which you want the relay to change state.
Is it safe to "cut" a 4-20mA line with a relay contact? I have connected a motorized valve on a temperature controller. The valve moves...
4,635
Hi all, I'm connecting several 4-20mA sensors together in parallel (only one shown below) The enclosure is ABS plastic with metal backplate DAQ...
275
Problem: Our PLC can only output 4-20mA, but the actuators it needs to control, modulate based on a 0-135Ohm signal. Buying 4 or 8 individual...
280
What's your go to 4-20ma isolator. I've got some 4 wire 4-20ma from several flow meters and scales that I would like to isolate before it gets to...
1,699
Hi, I need to read three 4-20mA signals from a DCS(ABB) in a remote 6 channel analog input module with RS485 modbus port. When I connected...
492
