Any Phoenix Contact Guru out there??
Joel201
Nov 2013
Calamba City
151
Good Day,
Anyone can teach me phoenix contact visu+ and pc worx.. i already know how to create logic for the pc worx i have problem with the OPC communication for the visu+ tags do i just insert Tags in the OPC Client DA and the TP will read it just fine or do i still need to configure other communication for it to be read by the TP like the ethernet settings can't seem to find one. Really confuse here in using phoenix contact any help will be appreciated.. right now i am just using the debug function to simulate logic in pc worx and trying if i can do a simulation for visu+ with it using OPC tags without actual plc.
Joel
You will require to have OPC Server first, that will retrieve the data & only then you will be able to direct tag your OPC tags. i.e in Phoenix contact there's ODP server that can do that work. You need to map it according to the program mapping and then only you will have physical connection between your PC and the Controller..
I am stuck on fail ctrl error 1013 cannot get IP nor can do firmware update need help pls urgent
215
Hi, I'm working with a Phoenix Contact FL NAT 2304-2GC-2SFP Ethernet switch, I already set the IP address and it has been working fine. I can...
1,378
Hi all, Historically i have used AB compactlogix exclusively working within the Logix/Studio5000 environment. I have decided to step out of my...
1,913
Hi all, first time poster and working on an existing PC TriSafe PLC for the first time for a project. I am wondering if anyone would know if...
1,139
(Rant)(CAD Models): Phoenix Contact Took the Time to say "FU!!" to their customers So obviously they have real CAD models of their parts because...
1,778
