Anybus AB7629 gateway communication problem
smartatuls
May 2013
India
30
We are trying to communicate GE CPE305 PLC (over modbus TCP) with the Siemens drive (Profibus) using Anybus AB7629 module which is Profibus master to Modbus TCP slave gateway. We have 11 words to be sent and read in PLC and configured the gateway for same(22 bytes) with correct IP but unable to establish successful communication between PLC and drive :mad:.
Can anyone guide us if we are missing to check anything?
Thanks,
smartatuls
In Proficy Machine Edition hardware configuration for the CPE305 (the configuration for the module itself, not the Ethernet port), under the "Settings" tab check the "Modbus Address Space Mapping Type" item. Make sure it is not "Disabled", which is the default setting.
Hello all and happy Friday, I'm curious if anyone here has experience sending data over an Anybus Bolt II (HMS AWB6001-A) using a Compact Logix...
808
We have a keg check weigher that that lost a fight to a forklift. The scale was previously a Systec IT3000, which was the only PROFIBUS slave...
704
Complete novice trying to integrate an industrial fluid filling process into MES using an anybus communicator Hardware: Anybus Communicator...
1,602
Hi, does anyone here sell the cable for the classic Anybus "PC connector"? I have a customer who has an old machine and he would like to retrieve...
1,853
We have been using ProfiBus Gateways to connect to a piece of equipment. The equipment interface is through a PB/PB adapter that we connect...
1,830
