ProfiNet Anybus gateway question
einnh
Mar 2014
New England
275
We have been using ProfiBus Gateways to connect to a piece of equipment.
The equipment interface is through a PB/PB adapter that we connect through a HMS Anybus ProfiBus to Ethernet/IP gateway.
The manufacturer of the equipment now uses ProfiNet. We purchased a ProfiNet to Ethernet/IP gateway but we don't seem to have the same options that we did on the Profibus gateway.
The part is an Anybus 7649. The issue is we can't tell the gateway where to look for data on the ProfiNet. This was a configuration on the ProfiBus model.
Edit1:
* We configure the Ethernet/IP side via add-on profile in our studio 5000 environment. We do not have that same type of access on the ProfiNet side so we can't load a Siemens G file onto the equipment controller. With the ProfiBus arrangement we just told it the data size and location on the PB/PB adapter. Again, we don't seem to have that configuration option on the ProfiNet module.
Ok I'm using an Anybus X-Gateway Ethercat to Profinet. I'm using TIA v15.1. I'm a little lost. I am trying to turn on an output to the Profinet...
1,720
Client would like to buy Anybus gateway product, to connect his PLC on Modbus TCP with IO device with Profinet. Basically, he needs gateway...
3,642
151
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
383
I want to establish a Profinet network in my production plant to connect multiple devices, including a PLC, HMI, and multiple Profinet-based...
19
689
