I have a CompactLogix PLC, 1769-L27ERM-QBFC1B
I have an Anybus ABC-EIP AB7007-B, Ascii Serial to EIP device.
I'm trying to setup the device to communicate to the PLC, and am having issues. Something I'm missing but I don't know what.
I have the serial device working connected to the ABC, I can use the serial device and it populates the Node Monitor in the ABC monitoring software, but the PLC is generating an error:
(Code 16#0109) Connection Request Error: Invalid Connection Size.
Tag: BADGE_SCANNER:I
(BADGE_SCANNER is the name of the module, and the input tags generated by it).
Here's a link to the configuration of the ABC and the Module Properites in Studio5000. http://imgur.com/a/jq1hl Everything looks right to me. 32 Bytes for the Data on the module, 32 SINTs for the input size on the PLC configuration.
I've tried a few thing like varying the data type (SINT, INT, DINT). But no luck. The PLC can see the device, but can't establish a connection because something is wrong with my configuration.
Thanks in advance.
Thanks in advance.
