Anyone have experience with EtherCAT?
Not so bad. I have seen a machine with 8 servo axes (also Beckhoff) making an electronic shaft serviced at 0.5 ms, camshaft controller with 32 outs also at 0.5 ms and few tents of IO at 1ms. All in one cable - TCAT System Manager shows only 4% of its bandwidth used. And it works.
[font=&quot]It’s another proprietary protocol only supported by Beckhoff. At least I don’t believe there are other makers of products for it. This should well on your high-speed application. Their software TwinCat is also good, but expensive with tag count costs and run-time fees. I would imagine that your OEM is paying those costs and passing it on to you through the total installed costs.
Joe_WaZoo
[/font]
Not completely true. Have look at http://www.ethercat.org/ .
However I've never used other devices than Beckhoff together with ECAT.
Compare TCAT with a hard-PLC with comparable calculation power and similar allowed number of IO - then it's cheap.
BTW, what do you mean refering to tag count in TCAT ?
Do you suggest that when OEM buys a hard-PLC then it gives you that PLC as a gift ? Grow up.
Hi all, I am experienced with Rockwell by have recently encountered a Bosch PLC. It’s an IndraControls XM21 V14. I installed the software and...
777
Hi all, Client called saying that the turbidity readout on the HMI is 0.0000 but on the local readout, it shows an actual value. Sure enough...
5,419
Specifically Sm10/20-TC. I have a customer that has a setup running a crosslapper, and this module runs the outfeed apron. They were having a lot...
1,342
Hi We are looking to implement some label checkers on some production lines. We want to check bar codes and best before dates. Just looking to...
3,426
Hello, I'm a big fan of the HART potential in getting multivariable off of complex instruments like flowmeters and some pressure sensors, but...
2,433
