Anyone with experience of offshore installations?
Weo
Feb 2006
Sweden
82
And especially oil rig of different types?
I´m thinking of trying some new branch out, someone here that have worked with design of systems to rigs or maybe on site experience's that can give me some info?
So anyone with some worthful info are welcome to write a line, I´m interested in everything, how system works,plc/dcs/scada,ESD, .. anything!
Working with automation today, just wanna learn more about oil&gas offshore.
Cheers
what do you need to know?
I'm planning of changing branch and I'm curious of offshore oil&gas.
Like I wrote above .. interested in anything that´s involved in the control system in some way.
Are you working offshore?
I used to work offshore maintaining production safety systems, flow computers, and everything else. Now I work on land as an administrator.
The drilling side has instrumentation but not much in the way of electronic controls. some of the newer rigs probably have much more controls with electronic drillers or whatever they call them, but I never really worked on that side.
I mostly worked on the production side maintaining safety systems. the safety systems handle safety and or control functions on the well and all equipment needed to process the gas/fluids from the well. the systems can range from no electronics at all to full electronic controls. just depends on what the customer wants.
I have some experience. Have been involved in drilling rigs, drilling ships and other marine/offshore vessels.
You will often find the same parts, the same PLC's (Siemens and AB are very popular since they are marine approved).
But the use is slightly different, offshore rules often require redundancy in power supply etc. so everything is more complex. Dual CPUs and dual communication links are very common. IP-ratings are also more important.
Hi all, I am experienced with Rockwell by have recently encountered a Bosch PLC. It’s an IndraControls XM21 V14. I installed the software and...
774
Hi all, Client called saying that the turbidity readout on the HMI is 0.0000 but on the local readout, it shows an actual value. Sure enough...
5,415
Specifically Sm10/20-TC. I have a customer that has a setup running a crosslapper, and this module runs the outfeed apron. They were having a lot...
1,336
Hi We are looking to implement some label checkers on some production lines. We want to check bar codes and best before dates. Just looking to...
3,409
Hello, I'm a big fan of the HART potential in getting multivariable off of complex instruments like flowmeters and some pressure sensors, but...
2,428
