Archestra I/O Field Symbol Animation (Event)
Apollas
Nov 2013
city
22
Hello,
Is is possible to create an animation action/script when I/O field input is finished/"ENTER" pressed within the Archestra symbol? For example, I enter value "50" and press "ENTER". When the button is pressed, I want to run a script/action.
Regards,
Giedrius K.
Using what software, Wonderware InTouch?
If so...
Why not use a data change script?
Im guessing that you want to do something once that value is modified, using a data change script will run your code every time that value is changed
Ash
Yes, I want to use that symbol in WW Intouch.
Datachange script doesn't do the job. It's a bit more complicated... I'm just trying to figure it out is it possible to do it within an Archestra symbol.
Basically, I want to have I/O text field and event script in the same symbol. When I click on a text field, the I/O entry pops up, but at the same time I want to execute a script.
Intouch doesn't allow to use both of these options at the same time, but maybe there is a workaround.
Hopefully someone seasoned can explain this to me. I have only ever used UDAs for my objects, but wanted to experiment with using a discrete...
1,835
So I made some changes to our plants WindowMaker application and I'm having trouble deploying the update to the live runtime. From the deployment...
148
Dear All, We are designing a solution with 1756-L74 and Archestra. We need to use SOE to show on HMI. Please mention any solution if someone did...
147
So I'm trying to enable history for a tag that is being used to display PPH on InTouch. I was able to locate the tagPath by finding the display...
710
Got myself into a bit of a jam this AM. Somehow the graphic editor hiccupped and when I went back into my graphic, everything was gone. I...
1,096
