ArmorBlock I/O Password?
Dec 2010
Burlington, NC
402
I am having trouble accessing the embedded web server of my 1732E-IF4M12R module. My digital modules accept the password fine, but the analog module does not. I have tried user=Administrator and password=<blank> as the manual says, both capitalized and not. It is a brand new module, so it should not have ever been changed. I also tried setting 888 to reset to factory defaults, with no luck there either.
Any ideas.
Try
user: admin
password: password
That's another one that Rockwell uses a lot.
I couldn't find a virgin to get blood from. So I tried FJaeger's idea and it worked.
I wish Rockwell would keep their manuals up to date with their products, or vice versa.
Thanks guys
Hello all, I have a 1732ES-IB16 Series A block that I have set the IP address on. I am unable to disable bootp using any method. I have tried...
346
Hello, I am stuck on trying to get an ArmorBlock, 1732E-16CFGM12QCR to respond to EIP outputs. My PLC is Panasonic FP0H-C32ET. I Registered the...
138
I am getting ready to use an ArmorBlock I/O module for the first time. All I have done so far is connect power to it. When I apply power it goes...
2,628
ArmorBlock 2-Port EtherNet/IP Module I am working on starting a plant up and we have a tremendous amount of these modules as the plant was...
2,533
Is there a armorblock type of that includes digital and analog I/O? All I can find is Digital.
1,433
