AS-I Configuration
eams2010
May 2009
Alex
26
I'm trying to create an AS-I system. The components I have are CPU 317, AS-I power supply, AS-I link advanced, IFM module AC5215 and Siemens module 3RK2400-1FQ03-0AA3. I configured the hardware, downloaded it, adjust the As-I link, set the address node for each module.
Only have the inputs are working in each module and they are reversed i.e., bit 3 is high when bit 1 is activated and bit 4 is high when bit 2 is activated.
I'm sure I'm missing something in the configuration. Can any body help in this?
Only half the inputs are working in each module and they are reversed i.e., bit 3 is high when bit 1 is activated and bit 4 is high when bit 2 is activated.
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
35
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
62
Hello I have a sensor that I read data with IO-LINK but I don't know how to get my data. I see that I have two modes : Process data Map0 and Map...
63
Kindly, we have the following configuration fault on a Kinetix 5700 axis. It only appears when we go online on the Plc. We are just starting the...
107
Hi All, Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration...
135
