AS-I Network Cable Question
Well how would one know wich cable your customer might have in use?
But in general, any high power 2x1.5mm2 (dunno the awg size, awg sizes are ******** anyway) should suffice. One reference says H05VV-F 2x1.5.
Terminators on ASi network
Hi All
If i fix two terminators on ASi network on length less than 100m, will it cause any other problem
Because we are not sure of network length inside the cable trays (many surplus cables)
Thanks in Advance
There is asi terminators also. If there is no problem with said network, why add any? If there is problem, first add one on other end, then if it is not enough add second. If those wont do the trick, you can try tuner (active terminator).
Hello guys, I had a problem in a local network where I have a lot of devices to a Stratix 8000 administrable Switch and this one to a 1756-EN2TR...
486
I know that Siemens have their own supports for where the Network/Profitnet cable enters the S7-1200 range, but they don't support standard...
2,394
I understand that 10/100 Ethernet recommends a max cable run of 100M (328ft). With something like industrial Ethernet IP, Does this still hold...
4,454
Hello everyone, Looking for someone with some fiber experience to answer this. I'd like to spec out an OM4 category fiber cable (50um). Will...
2,207
Hello Everyone, I have a Allen Bradley SLC 5/02 with a link coupler 1747-AIC connected together in one PLC Cabinet. There is a HMI which...
1,491
