Ascii barcode registers
peterdragon
Feb 2012
Benton Harbor
Greetings,
I have an intermec 3400 barcode printer that is connected via a pro soft mv146-gsc caed in a slc 5-03 chassis. It gets data from an ascii register file. I need to move the print around on the labels sometimes for different models and part numbers. Sometimes numbers just dissappear when I change the number in the register file. And I have to download program back in it. For example regester a106-25 and a106-77 I change those numbers I lose part numbers and cant get them back even if I put origanal numbers back in. I suppose that has something to do with buffer files Mi. What I was wondering if anybody knows exactly what every register does in file. In register a106-7 will move bottom l/h part number vertically up or down, by increasing or decreasing number. I just would like to be sure of what I am doing as printer is in an assembly machine, and I don't want to disturb production if I have to redownload program. Hope there are some barcode guru out there. Thanks
Hi to everybody. I need to read the first 12 characters of the message that a barcode reader sends to the ascii card (1734-rs232 ascii) and I...
748
hi, i try to capture barcode data using UDT with SINT ascii array. i have all the data i need but it in array format, how can i convert to 1...
3,083
Hi All, I have application to read data from barcode scanner to S7 PLC through SI ASCII Card (RS232C). I have tried using the standard FB's to...
2,607
Hello all :) I am experimenting with a Barcode reader and DL06 and have created the program that reads in the ASCII code. I have a few problemes...
3,864
Hi, I'm working on an Omron CPM2C plc that is communicating with a Microscan MS-3 laser barcode scanner. I need to read a label with two...
8,979
