blackhenry
I'm an entry Student for PLC , i got one assignment from the teacher and still stuck for 2 weeks, now i'm begging the professional to help me this project (
Stage1: I have to design a program for an engineering workshop. This workshop has two very large compressors which feed air into a holding tank. On the top of this holding tank is pressure switch. The way this system work is when the tank is empty the pressure switch will close and only the first compressor will star to fill the tank with air. When it is full oc air the pressure switch will open its contact thus stopping the compressor. As the air is being used the pressure switch closes to star the compressor, now being the second one. This process repeats its self five (5) times , then a warning bell must sound for ten (10) seconds to let the operator know he must add oil
Stage 2: A low pressure switch has been added to the tank. When the air stays too lo for 5 minutes, the plc starts both compressors and runs them for 10 minutes and then return to normal duty. This emergency start does not count toward the bell cycle
