Henry, A situation that is worse than receiving no help is receiving erroneous help that could lead you astray.Thank you so much with yasirkhi about helping me, i'm so grateful about that. Thank you.
Of course there's something missing. You weren't expecting to let Lancie do the work and you getting the credits, weren't you?Lancie,
i tried your flip logic, something is missing. Please check again, post only flip logic the simplest one, i will really appreciate that.
Waiting.
Yasir, wait no more! Here is alternator logic that I think is about the simplest one, and the one used in my posted program. To use this logic, of course you have to set up your program rungs correctly.Lancie,
Waiting.
Well , if he can helps me, i won't ask you guys for help, he just seat on the chair, playing with computer and see youtube , how great life is that , huh?
Thank you so much with yasirkhi about helping me, i'm so grateful about that Thank you
If this guy is still doing this course - I doubt It
THE courses like this finished in november last year
He may be doing some other course now
The pressure switch is normally closed when it is laying on the shelf (not installed and prssure = 0). It opens when pressure = setpoint, and closes when pressure = some pressure lower than setpoint but not 0.Thanks Lancie. I didn't understand the rung 003 that High pressure switch to be normally closed.
As the air is being used the pressure switch closes to start the compressor, now being the second one. This process repeats five (5) times, then a warning bell must sound for ten (10) seconds to let the operator know he must add oil.
Stage 2: A low pressure switch has been added to the tank. When the air stays too low for 5 minutes, the plc starts both compressors and runs them for 10 minutes and then returns to normal duty. This emergency start does not count toward the bell cycle.
Thank you
