Assistance with a basic ST function
techkarlsson
Jun 2013
Stockholm
I'm currently working on a centralized water system in an industry and I figured this could be a good moment to practise some ST with arrays.
The system consist of 7 refillvalves which opens on command from a level sensor. A flow sensor confirms the function of the valves.
What I'm trying to write with ST is a function that triggers an alarm if one valve is commanded open and another flow sensor also senses flow. The output needs to be an array of all 7 valves/sensors in order to reduce troubleshooting time.
Summary: During refilling of one water tank two (or more) flow sensors registers flow, a fault (valve specific alarm) will be sent and the system shuts down.
Please ask if I've missed out some important parts...
for valvenumber 1 to 7;
if level(valvenumber) = low then valve(valvenumber):= open
else valve(valvenumber):=close;
end_if
for flowsensornumber 1 to 7;
if flowsensor(flowsensornumber)<> valvenumber do
if flowsensor(sensornumber)= flowing then alarmtrigger on.
end_if
end_if
end_for
end_for
here comes the alarmtrigger and reset
something like this?
i know you write in codesys so fill in the extra tokens.
Hi, I am looking for a website to learn C++ and visual basic. Does anybody have a suggestion? Thanks.
3,227
The idea here is to provide for a brief rapid influx of message codes while preventing sequentially repeating the same message. i.e. if two...
23
710
Hi All, This is my first PowerFlex 755 drive setup and I am having an issue with when I start the drive it runs at my minimum speed 5Hz, but...
459
We're upgrading an old PLC-2 system programmed in ICOM. We have the files, the PLC logic is in a .LAD format. Does anyone have working...
434
I am a complete newbie to this stuff and wanted to try this out and was looking for any information on how I can complete this by Wednesday...
19
12,786
