Atlas Copco Run Down Tracking
Gadelric
Nov 2018
Midwest
137
Team,
I have the need to gather the run down info from the copco controller to my PLC.
I have an Allen Bradley PLC running v28.
Has anyone here tried to gather this data in the PLC?
I was told there are 3rd party programs that will do this for me, but I would rather do this in house via the PLC.
Any assistance would be greatly appreciated.
Gad
Atlas Copco to Allen Bradley
You will have to supply more information - which model of A-C - PowerFocus or Power MACS? Which A-B controller? What communications options do you have: serial, EtherNet ...?
Atlas Copco Elektronikon controllers are CAN protocol based. You'll need a CAN/Modbus converter. Atlas Copco has produced a number of these over the years (ComBox E, ComBox S, etc etc). They are a bear to setup, and usually you'll need to get Atlas Copco onsite as they hold the config software tight to their vest. Also they offer no support on how to digest the data, which isn't a big deal with most of the data until you get to date and time stamps. They don't tell you how to unpack the data.
there is an interface module that can be used to interface between the plc and the atlas copco unit.
we stored over 1500 data points per station, 5 stations per shift.
sorry, it's been to many years ago since I used the product.
james
After quite a bit of searching, as well as the information provided here by you amazing users, I think the desire to have this information collected in the PLC is not quite as simple as using a GSV. We don't have enough torque guns on our production floor to justify spending more money for data collection. We have had our off shift tech pulling the cycle counts from the controllers and I think we will just keep doing this. Maybe at a future point I will be able to justify more software/hardware.
Thank you all again for your assistance.
I did this with the Powerfocus controllers in a couple of ways:
1. The more difficult but also more fun method, using a serial-to-ethernet gateway from RTA Automation. Serial on the PF and ethernet to AB Compactlogix. You do have to obtain the open protocol document from Atlas Copco to figure out all the handshaking.
2. easier method, purchased and installed EIP fieldbus adapters in the powerfocus controller, then just add the adapter to your AB IO tree.
Hope this helps.
If it's power focus using EIP, it's very easy to collect info to your PLC
Sorry for the late reply, this project was put on hold for quite some time.
I have time to review this project again.
Is there some information as how to go about this. These units are all connected to the PLC with Ethernet IP.
I have not been able to connect to the PF via ethernet though, I have had to use my USB to USB-d cable to connect to these devices.
Book supplied by atlas Copco when you get the tools talk software doesn't help much.
It was hard trying to find the software ECT for this drive. Finally, I found it but since it is very old it is not intuitive at all. Is there a...
107
Hi Guys, I'm looking for a download for the ToolsTalk software for atlas copco controllers (power focus). The laptop that had it died and of...
3,168
Hi I´ve been looking around the web trying to find programming software for Atlas Copco DMC drive series..(Example: DMC 50720) This far I...
2,506
Wizards, Has anyone used the wireless torque gun set up from Atlas Copco? I was asked to see if it would be an improvement to change over to...
1,295
I'm most likely out of luck here, but I'll give it a shot to ask... Does anyone have the following software? PAM Tools SAM Tools ProMotion...
20
6,951
