Auto configuring failed on find the baud and parity
Koid
May 2017
US
I'm new to PLC, I'm using MicroLogix 1000, using USB-1761-CBL-PM02. When I try to use RSLinx Classic Lite to do the auto configuration with RS-232 DF1 Device, it shows failed to find the baud and parity! Check all cables and switch settings!
I made sure the com port is correct by checking the device manager, using SLC-CH0/Micro/PanelView. But still showing this error message. On my MicroLogix 1000, both power and fault LED light are solid. How do I fix this?
I'm using desktop windows 7 64 bit OS
That is not good (fault light on solid), see pdf.
Also if using a USB to serial adapter, not all will support autoconfigure.
You might try to set RSLinx manually
9600 baud
No Parity
1 stop bit
CRC error.
Welcome to the Forum !
Unfortunately, that MicroLogix 1000 is not functional if it has a solid red FAULT LED. You can attempt to clear it by power cycling, but in general the solid red FAULT means that somebody sold or gave you a damaged or defective controller.
So I need to contact the seller to solve this problem, right?
Did you buy the controller from an Allen-Bradley authorized distributor ?
In general, if you buy a defective or damaged piece of merchandise, your recourse is through the seller.
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
95
Hello everyone, I'm new here. First of all I just want to say that you guys are very knowledgeable and reading your posts on here has saved my...
185
Hello, I m having a problem with wago 750-862 plc. The plc won't start automatically in run mode after a power reboot. I've also tried the...
380
I have 32 masters in a linear topology network chain. I would prefer to use AL1xxx series from IFM. They do support device level ring if that...
1,045
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
616
