auto mate 15
Using the "Search" button at the top, try keyword "reliance" or "automate"
Try this site for information:
http://www.automation-consulting.com/aps/aps.htm
There was a hand held programmer made for these units as well as programming software. If you are going to use a computer you will need an old DOS based computer (Windows98 or older) and some software called "APX" programming software. The comm port uses standard RS232. I have an old manual somewhere if you need more info.
thanx,my task begins, i suppose i will have to locate a specific 9 pin rs232, i have some i used for connecting to ab 501?
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
81
Hello everyone, I'm new here. First of all I just want to say that you guys are very knowledgeable and reading your posts on here has saved my...
176
Hello, I m having a problem with wago 750-862 plc. The plc won't start automatically in run mode after a power reboot. I've also tried the...
359
I have 32 masters in a linear topology network chain. I would prefer to use AL1xxx series from IFM. They do support device level ring if that...
1,031
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
597
