Automation Direct RS232 to Micrologix 1100 Ethernet
analyzer tech
Jan 2015
baytown, texas
Okay here we go. I am new to this and I need to know the easiest method to mate an Micrologix 1100 to and Automation Direct with RS232. I have a Lantonix converter. But is there an easier way?
Just add a small ethernet switch, then you can connect the PLC, HMI and your programing PC all to the switch using CAT5 cable with RJ45 connectors.
(Standard ethernet patch cables)
BCS
EA-MLOGIX-CBL
This is the easiest way. I am not a big fan of converter they are not robust specially cheaper versions. So get the hmi with ethernet port or use 232 cable.
690$ maple hmi is the best in price.
Is there an option to go from RS232 to Ethernet with a cable or would I need to use a converter? If so what is a good option to use.
Posting late last night and did not look up your model number for the HMI before posting.
Looks like you do not have Ethernet on you HMI, so the link to the RS232 cable will be the way you want to go with this application.
BCS
The easy way using the cable.
But you must try lantronix too shouldn't be too hard since you already have it.
Find another cable at automation which one end is DB9 and connect to lantronix.
What lantronix model you have?
Dear All if any body can help me in establishing communication B/w WAGO RS232 module and automation direct My Controller is 750-841 and...
6,637
Hello, I have an automation direct d2 262 plc and C-more HMI EA9T6CL-R. I need to prepare a program, scheduled to be performed on a future date. I...
126
Hello all- I have a unique challenge using a customers Direct logic 06 PLC. This customer has a DC motor operating at 10 RPM which is turning a...
138
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
570
Anyone tried Automation Directs new CM5 HMI. We've been the EA9's for a few years now with minimal complaints. A few failures here and there but...
17
1,595
