I have worked a little bit with B&R 2003. Usually, when the CPU suddenly went to service mode, it was because the program is lost. This is possible since it only has battery backup. There is no EPROM or Flash or similar.
So I suspect you have to replace the backup battery, and load the program anew.
If you think that the program is still on the CPU, then do not power it off when replacing the battery !
