B&R Automation Studio Ladder Techniques
nerdfactormax
Feb 2008
Adelaide
17
I am trying to transpose some ladder logic from an AB ML1500 to B&R Automation Studio and I have been stumped by some seemingly trivial logic. Example:
If bit 'A' is on, then move value '0' into variable 'X'.
In RSLogix this would be one rung. It seems that to do the same in AS requires jumps and labels. Am I missing something?
You are right.
The MOVE instruction in IEC61131-3 is strange to put it mildly.
If it shall execute conditionally, you have use jumps as you say.
In IL, the move command will look like this.
LD 5
MOVE
ST array1[3]
However, the MOVE instruction doesnt do anything. You could just write
LD 5
ST array1[3]
And I also find the B&R ladder editor very very crude.
Hello all, I’ve recently begun using Automation Studio on my own time to boost my knowledge of controllers beyond AB/Siemens. To ease myself into...
914
Hello everyone,i am a final year student.I would like to ask help for my final year project: This is the problem...
15,785
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
588
Hello Experts, I recently stumbled with an issue about ABB VFD ACS800 connected with B&R PLC X20CP1484-1. This ABB VFD ACS800 somehow got...
332
Hi, I would like to prepare a project for the operator panel and I do it like this: New project -> I choose the appropriate panel -> add object ->...
443
