B&R X20 plc trouble communication fault
Jam2812
Jan 2023
India
Hi
I am biginner in B&R plc .
Purifier system is transmitting the data to remote display unit.
Currently there is no reading is display on remote system.
I am not having access to program.
Please advise.
Details:
I am having trouble with X20 CS1030 communication module, its TX led light is not blinking and e led is flashing.
Restart the module, e led light stop flashing but TX led is still not flashing.
Bus control module: X20 BC 0083.
Checked bus control module: SE led in green on and L/A 1F1 flashing.
The above problem started after the power shut down.
Basically bus control module receive data through RJ45 lan and then communication module CS1030 transmit the data by RS422 to other system to display the data.
Hello, and thank you for reading this. A connectiom between a X20 PLC, a ESA SC103A screen and a Yaskawa V1000 inverter. The X20 seems to be in...
1,513
Hi Experts, Is it possible that panelview plus panel can talk to b&r x20 cp3584 plc? I need log some data with panelview plus screen from another...
2,168
Hello, I'm having problems with a BeR X20 BC 0043 module. The LED flashes twice green and once red. Reading the manual, I believe that this...
51
Hi, i have a PLC B&R X20 CP3484. The machine was shutdown for months due to which I got to loose the plc battery, in the same time ethernet...
117
Hello, We have a B&R X20 CP3584 controlling our printing press communications. The program on the compact flash card wont load, we were running...
945
