Barcode I2of5 Check Digit
bernie_carlton
Apr 2002
Yakima, Washington
6,413
I'm using a barcode reader and was having trouble reading I2of5 barcodes. The scanner manufacturer's people advised me to turn off looking for the check digit as - they say - many make it incorrectly. Well, looking at my customer's barcodes and looking up what sources I could Google it looks like the check digit was done correctly. Could the bar code scanner manufacturer be wrong?
The question is - does anyone have a real ANSI reference for the generation of the check digit in Interleave 2 of 5 barcodes?
Hi Bernie,
I use "I 2 of 5" all the time and have never used the check digit. I do know that there are two check digit standards: USS and OPCC.
I have never researched the difference - so can't give you any more to go on than that . . .
Good luck,
Marc
78
Hi to everybody. I need to read the first 12 characters of the message that a barcode reader sends to the ascii card (1734-rs232 ascii) and I...
743
I thought I was nearly finished on this TIA Portal/s7-1212C project (famous last words)... Up until now, I'd developed the PLC/HMI such that the...
1,607
Does anyone know a way to dynamically generate a 2D barcode on a PanelView screen? An Activex Control maybe? If such a method is out there, it...
3,018
I'm wondering if anyone has a solution where I can use a barcode scanner to input a string into a PLC tag. All AB hardware/software. I'm aware...
17,989
