Barcode reader - OPC
Bar code scanner to OPC or PLC or BOTH!
We have a product called DeviceMaster UP, which effectively allows a serial device AND an Ethernet device the ability to communicate simultaneously to the PLC via it's native Industrial Ethernet networking protocol (Ethernet/IP, PROFINET, Modbus/TCP) and via TCP/IP to an application (OPC).
If you'd like additional details, please contact me directly, or feel free to do a web search on DeviceMaster UP.
You can use any RS232 bar code reader (we use the Dragon D101) and for example a converter RS232/Profibus DP from Siemens 6ES7158-0AA01-0AX0
If your panel has usb ports like newer Siemens panels and the scanner suports keyboard wedge you should be able to connect the scanner this way. The downside with this connection i think would be that you need to have the right input field selected for the data to be transfered correctly to the panel.
In a recent project we used scanners and distributed rs232/dp gateways from Sick i belive that the have gateways for the most common field buses this requiers more hardware and programming but it would give you a more flexible solution
Depends on the application. I use them for data entry on our PC based systems not for scanning boxes going down a conveyor. These units are USB and the computer sees them just like a keyboard so no software needed unless your using a special code.
www.waspbarcode.com
Hello Friends Is it possible to connect a serial barcode reader to a Delta HMI? I am lookin DOP103BQ and DOP107CV. I have serch in manuals but...
1,384
Hello Friends I have a machine with a barcode reader connected through serial port to a GS2110 HMI and a FX3G CPU. Where can I found the tag...
1,627
Hello all , I have a project including S7-1200 and sick sensor lbc642 I need to communicate with the camera through ethernet tcp/I using t_send...
2,262
Hello, I am on a automotive line right now (4 segments) and we have a barcode reader at the beginning of each segment at the elevators. The...
2,294
Hi guys, I hope you are all doing well. I'm trying to connect a SICK BarCode Reader (CLV630-6120) to RSLogix in order to use it with my PLC...
4,298
