SCUBA NooB
OP
For anyone following this thread I have had Erwin Sick's reply and it was "Glad you got it working, goodbye"
Can you give me the output and input instances?Sorted it. For another NOOB like me it IS as simple as people say. Add it as a "generic Ethernet module", set the instances (for me I copied another working program as Erwin Sick still wont issue this info OR a "memory map") This then creates the array in the controller tags as if it is a bog standard input/output card. View these tags and there is a barcode plus other info from the scanner (with no "map" there is no easy way of knowing where "good read" goes etc...). Thanks for everyones help.
