We are going to use (5) bar-code scanners connected to a 1768 Compact-Logix processor via ethernet. Each scanner will have a unique (static) IP address.
What (ladder / function block) instructions are used to accept the incoming data that the bar-code scanner is going to broadcast? (Scanners will be set up to broadcast one data string on a successful read)
We can trigger the barcode scanner in three optional methods:
1. Continous scanning - and broadcast one burst of data on read success
2. Digitally triggered read scan via PLC output and discrete wiring.
3. Commanded to trigger a read scan via the PLC program over established ethernet connection. (Desired method)
What (ladder / function block) instrucion would be used to send the "read" command to the scanner at a fixed IP?
Lasty, any caveats using Ethernet to scan bar codes?
5 scanners, each scanner would need to read about once every 30 seconds.
Thank You
Plastic
Thank You
Plastic
