Barcode Scanner Not Scanning: FactoryTalk View & Kepware Enterprise
W.Bartek
May 2013
Michigan
Hi -
Recently, I upgraded the firmware on a PanelView Plus 1000 to V 5.10.10; I think it was V 4. This meant that I needed to update the .MER files. I used FactoryTalk View Studio V 7.00.00 to do this. With the PVP at V 5.10.10 and the .MER loaded, the program seems to function fine except for the barcode scanner used to input part numbers. I tried using UCON driver but have had no luck yet. Not sure if I am not setting up the driver correctly or if I have an incompatibility issue.
I am also not sure about this. How about trying another barcode scanner to have a try. Last time I also almost encountered the same problem. The barcode scanner did not work. It was a rich functionality barcode tool which supoorted to read more than 20 barcode types. I just want to read QR Code. So I changed one QR Code reader and it worked greatly. So I suggest you change another tool to have a try.
HI there
It is indeed a wise choice to own a powerful barcode scanner.So i am looking for a barcode scanner.I know there are many third party program for barcode scanning.I want to know that if there is a free trial for your barcode scanner?I'd like to have a try.Thanks a lot
Follow the hardware connection
Hi -
Barcode scanners have numerous output options:
RS-232 ASCII
Ethernet
USB
Keyboard wedge
When you changed the firmware on the panelview, you probably lost a DRIVER installed by the original integrator. Again, identify the required hardware connection, and add the driver back into the panelview.
I thought I was nearly finished on this TIA Portal/s7-1212C project (famous last words)... Up until now, I'd developed the PLC/HMI such that the...
1,574
I'm wondering if anyone has a solution where I can use a barcode scanner to input a string into a PLC tag. All AB hardware/software. I'm aware...
17,977
Hello Everyone. I am working on a project where I need to scan in 2 Barcodes to populate 2 different tags. A glue Batch and a product serial...
3,105
hi guys, I have to write a program to trigger and receive data from a barcode reader via an RS485 module plugged on Wago PFC 200. Does anyone know...
2,738
I have a barcode scanner reading bin labels and handing a string to an Laser Guided vehicle to place the bin in its appropriate location based on...
1,270
