Barcode to Excel to PLC
wfo
Sep 2007
Idaho
I am trying to get a digital output based on a barcode read. The scan talks to an IBM AS400 where it is verified as good or bad, if it is a bad scan the AS400 throws a 1 in an excel cell on a PC. I need to get an output to sound an alarm when that happens. I have a Direct Logic 05 PLC with Ethernet, and KEPDirect for PLC. When I get this to work they will be speread out all over the plant making an expensive application like Wonderware unreasonable. I have also tried Wago Field Bus but I dont write VB or C# so I can't make it work either. I would greatly appreciate any advice.
Are you wanting the PC to supply a digital signal to the PLC?
I can possibly give you a very quick VB example to turn on a signal line of a parallel port which can then be fed to a solid state relay. Then use the output of the relay to feed a signal ti the PLC.
This would be a very cheap way to do it, but only if your PC has a parallel port.
That's a great "down and dirty" approach! I used a cheap USB controller connected to relay boards for a similar application - (computer controlled automated bar as a fun project).
wfo
I have attached an example excel file to do the job.
There is another file named inpout32.dll that needs to be copied to the directory :
C:\Windows\system32
This is the driver that allows excel to access the parallel port hardware.
If you change cell A2's value to a 1, then output comes on, otherwise it goes off.
In Excel, if you go to Tools->Macro->Visual Basic Editor you will see the code. You may need to edit the address of the parallel port. It is explained in the comments on the code.
I will post a video and details of a board I use that gives relay outputs.
Video of it in action
Ok, here is a link to a video to show the above attached files in action:
http://www.youtube.com/watch?v=mWQU5atBgGY
The following link is the board I used:
http://www.electronics123.com/s.nl/it.A/id.1712/.f
I also got a cable part # BB040 for $5
It requires a 12V power supply. I ordered part # BB151, but found out that it does not supply enough current to keep all 8 relays energized for more that 10 seconds before going into shutdown.
64
Hi to everybody. I need to read the first 12 characters of the message that a barcode reader sends to the ascii card (1734-rs232 ascii) and I...
737
I thought I was nearly finished on this TIA Portal/s7-1212C project (famous last words)... Up until now, I'd developed the PLC/HMI such that the...
1,593
Does anyone know a way to dynamically generate a 2D barcode on a PanelView screen? An Activex Control maybe? If such a method is out there, it...
3,011
I'm wondering if anyone has a solution where I can use a barcode scanner to input a string into a PLC tag. All AB hardware/software. I'm aware...
17,985
