Basic PLc
tguclu
Dec 2003
Hi ,
Can someone explain modus and profibus here ? and PLc networking techniques ?
I believe this is the most important thing if one wants to build up a PLC network (small / large).
That is a very large topic, and can't be covered in a forum like this. Suffice it to say that Modbus and Profibus are two "protocols", that is they are two forms of creating data string enquiries and responses. Protocols include headers, checksums, commands, adresses, and data and are PLC platform specific.
You also have to have the communications parameters - baud rate, error checking, parity, number of data and stop bits - defined for a network.
Finally, there are various communcations configurations available. RS232 is a short distance serial link, RS485 is a long distance serial link, ethernet is both a data packet standard and a hardware configuration (but NOT a protocol). You can use copper wire or optical fiber for the transmission.
As per the title, does anybody make a basic PLC that directly supports IO-Link without requiring a fieldbus and remote IO modules? I know it goes...
1,676
Create ladder logic program to count 4 on pulses (not using a counter) and then turn the output on if the on pulse input signal can look like the...
105
36,656
Hi Friends, I'm making a PLC operated chocolate vending machine, using a CLICK Basic PLC (C0-00DD2-D) which has 2 x RS232 ports. I'm also using...
1,536
hi all, which AB PLC or module that runs on BASIC language? thanks
3,566
Hi all, First time posting. I'm an new journeyman electrician from Canada trying to move to the industrial side of things. I have so far written...
5,865
