basics
laura_jenny
Oct 2012
scotland
thnks for ur help i have started learning
can u say simple words where to use NO and NC
this is bit confusing me normally open means its high curent will flow,
normally closed means current will stop no current will flow .so can any one explain it when to use and when not to use
thnk u
When dealing with electrics you should always consider the term "closed" as current flowing through the contact.
At least I can't think of an example of the opposite.
when power is switched On to a device the devices state can change from either On to Off or Off to On.
this is where the names of NO or NC originated from.
it is the state of a device with the power normally OFF or when the device is physically released or Free from operation.
You will hear the AB terms of XIC or XIO (NO and NC respectively)
this is specifically internal PLC programming, not external devices.
When a water faucet is open, water flows. For electricity, a closed circuit is a complete loop and allows current to flow. The basics of PLC programming is relay logic. Start with some basic electrical circuits and relay circuits.
At one time, "with the power normally off" would have been a definitive condition with no way to misinterpret the meaning. Now that are solid-state devices (relays and timer relays) that have four different power states: control power on or off, and signal-switch power on or off. Some manufacturers have started defining a case with control power on and signal-switch power off to be the same as the old "power normally off" state. This is where specifications become confusing and errors creep in.
Easy for you Lancie, probably not for her. Open, nO flow, Closed, Current flow, 2 bits heah
I would not ever use those terms to describe the terms "normally open" and "normally closed". I think trying to put those in terms of current flow is a big mistake for any student.
This is a bit confusing for me: normally open means its high curent will flow, normally closed means current will stop (no current will flow)
Laura-jenny, I can see that would be confusing because your description is EXACTLY BACKWARDS to the real true original meaning of NO and NC. For a NO switch or contact, no current CAN flow because the current path is open, and for a NC switch, current can flow through a closed path.
Now for the equivalent PLC instructions that read input signals into PLC memory, that is a different story and should NOT be confused with "NO" and "NC". They are two different concepts or functions. Trying to make the two things equal is like saying apples and oranges are equal.
Laura,
You have started at least three threads titled "basics", this gets to be a bit confusing. How about choosing one of them and tack all your posts to it?
:ROFLMAO: How would a beginner know the tremendous amount of stuff that has to be a part of the Basics foundation? As long as she doesn't get into "Advanced", we are good to go! šŸ™ƒ
If you want to see confused, try explaining to a green electrician the logic of a NO relay connected to a NC solenoid supplying air to a NC actuated valve that is operated by pressing a NO push button.
I'm trying to use a MOVE function as part of a sequence on Siemens S7-1200, but the program control isn't doing what I need. MOVE in TIA Portal...
1,816
On siemens when you have V15, 16, and 17 on the TIA portal is it like Rockwell where the version and firmware in the controller must match or can...
3,013
Hello! I'm a complete beginner to programming and i have a project i'm working on in TwinCAT 3 since i'm using a Beckhoff PLC. One of the...
2,360
Good afteroon, I am new to programming Panelview plus 7 using Factory talk from AB. I successfully uploaded the .mer file from an HMI screen. I...
6,355
anyone got an recommendations for books, websites, blogs, whitepapers, whatever that cover panel design best practices? the short of it is, im a...
1,725
