Beckhoff Disconnecting itself
zawthet
Oct 2003
Singapore
We have a strange problem on Beckhoff PLC.
The system disconnecting itself after certain time. We are using BK2020 Economical Bus coupler to connect to FC200X interface card in PC. We need to restart the system after it was disconnected.
I don't think it is a problem with System Manager or PLC program as we have two other identical system running together right now without any problem. We tried to replace the BK2020 module with the module from other system and also the light bus cables. But the problems still cannot be solved.
The only differences in the system that we have problem is OS (WinXP and Win2K). Beside, PC is newer and faster than other system.
If anyone have similar experience before, I will appreciate your advice.
Hi I'm new working with Beckhoff We have 40+ CX2030 twincat 2 PLCs but almost every day at least one will drop from the network and loose...
1,311
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,026
Hello sameone have Beckhoff PLC Siemens Sinamics V90 configuration example?
101
hello, I am using Beckhoff with TwinCAT3 and when I change or add some new hardware or for any reason, there is a mismatch in the real hardware vs...
130
I have a Beckhoff CX7000 IPC with some digital I/O built-in and I additionally need two analog inputs 0-10V. Can I install both Ethernet terminals...
210
