Beckhoff losing persistent data values
Kick...
Similar problem with a BC9120.
Need variables to be Modbus TCP accessible and if you try to declare a RETAIN or PERSISTANT variable as AT %MD0:Real it will compile but not retain through power cycles.
Any suggestions or sample code would be much appreciated.
[email protected]
I remember experimenting with a BC of a CX (this I don't remember) and I had the same problems.
i phoned Beckhoff and their support said something about using a UPS.
I thought he was talking about a hardware UPS but it was a function block that you have to use to retain data when you loose power.
Maybe somebody has more knowledge of this functionblock?
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,013
Hello sameone have Beckhoff PLC Siemens Sinamics V90 configuration example?
99
hello, I am using Beckhoff with TwinCAT3 and when I change or add some new hardware or for any reason, there is a mismatch in the real hardware vs...
127
I have a Beckhoff CX7000 IPC with some digital I/O built-in and I additionally need two analog inputs 0-10V. Can I install both Ethernet terminals...
208
Hello, We are currently working on a project that involves connecting a linear potentiometer to our Beckhoff PLC. After researching, we...
197
