Beckhoff Nema17 contol with TB6600
PaveLC
Dec 2023
Frýdlant nad Ostravicí
Hi everybody!
I am new to the Beckhoff system and I need advice on how to easily control the TB6600 controller. Has anyone solved this problem before or do you know a tutorial that I can follow? I am going to use it as a controller for a stepper motor as an extruder for the SCARA 3D printer. So I will need to follow somehow the G-code and give the instructions to the controller. Thanks for your answers.
TB6600 is a generic stepper driver.
It has 3 input signals, one enable, one direction signal and one pulse, the stepper does a step(or micro-step) every time you give it a pulse on the pulse input.
Since those inputs are all on opto-isolators its a matter of sizing the correct current limiting resistor and it will accept 24V control signals.
It is also important to say, that I need to control it with the standard output terminal EL2008
Sorry but that isn't going to happen. The EL2008 is a standard digital output terminal. It doesn't have the switching speed necessary to drive a stepper. You could use it for the direction input on the TB6600, but the pulse signal needs to be from a high speed PLC output. If you're using Beckhoff I would suggest the EL2521 terminal.
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,013
Hello sameone have Beckhoff PLC Siemens Sinamics V90 configuration example?
99
hello, I am using Beckhoff with TwinCAT3 and when I change or add some new hardware or for any reason, there is a mismatch in the real hardware vs...
127
I have a Beckhoff CX7000 IPC with some digital I/O built-in and I additionally need two analog inputs 0-10V. Can I install both Ethernet terminals...
208
Hello, We are currently working on a project that involves connecting a linear potentiometer to our Beckhoff PLC. After researching, we...
197
