Beckhoff twincat change programming language
JOLTRON
Aug 2006
MI
692
Hello all,
I have a new project coming up and it will require me to use twincat. I went to the beckhoff site and downloaded the 30 day trial to get a fell for it, but I can't seem to find where to change the programmin language to a Structured Text style. I tried opening the help file and that told me to download a full version. I tried opening a few help files online but they all said web page cannot be displayed. Can anyone help?
-Joel
Hello all,
-Joel
When you insert a new POU, you select the language, see attached picture.
ADDED: Also if anyone knows of a tutorial on how to setup and map I/O with the system manager it would be greatly appreciated. So far I have found OSCAT and have downloaded some basic programming examples from there.
Thanks WEO, but how about if a POU is already created?
I've clicked them, doulbe clicked them, right clicked them, edit object. But can't find anything to change something already created :(
This tutorial is made of a forum member, Archie, I think it´s a great if you´re a first time user of TwinCAT.
Maybe there´s more videos on youtube, do a search for Beckhoff.
http://www.youtube.com/watch?v=l_nFE9wx8OM
I haven´t found a work around this, I think you must add a new POU and choose correct language from there.
You can convert POUs between certain languages, although I haven't tried it so I am not sure how it works. If you right click on the relevant POU it will give you the languages to convert between.
I have just completed my first project with TwinCat using 12 BC9100 controllers. Using ST to create custom function blocks meant the programming went quickly and chages to a single FB would be quickly copied across all the other systems.
Whilst I am sure other IEC languages function in a similar way I really liked how easy TwinCat made it to get the project how I wanted, and the integration with Indusoft was easy as well.
Jon.
Jon.
Thanks, totally missed that with the conversion, maybe it wasn´t there in earlier versions.
Tried it and it works like supposed.
Sweet, thanks.
I never would have looked into converting it. I thought it would have been more Like the Siemens 300 series where you just select your option under the VIEW menu option.
Hi everyone, I'm currently finding ways to create variable that can be read & write between 2 Beckhoff controllers. Target to be achieved: 1) PLC...
2,324
18
1,073
Hello, I was wondering if anyone know how to upload a PLC program to the Beckhoff TwinCAT 3 from a file? i.e. without having the development pc...
792
Hi anyone got any tips and tricks?? I'm at a stage wherei need to tidy up my hmi project and give all objects sensible names, I did start this...
971
Hello, I have a System running a beckhoff IPC with twincat 2 software on it, Also i have no original source code. Is it possible with the...
1,279
