Beijer E100 HMI & FX1N
Botbuilder
Jan 2008
Gloucester
Can anyone tell we where to find a simple program that demonstrates how to display a couple of messages and look at the function keys of Beijer E100 HMI & FX1N combination. I have EDesigner, GX Developer and all the hardware connected up in my living room. I am quite used to the old Medoc system but I can't quite get my head around this new stuff.
I'm only a simple soul,so it would help if you make things blindingly obvious
I find the help files in EDesigner + GX Developer about as helpfull as my first wife.
Any help/advice more than welcome
A very quick lesson on using the function keys as buttons;
Open 'Main' block the default and starting screen.
Double click on a function key (a new screen opens)
decide wether this button is global (the same for every screen)
or local (only active on this screen)
Then chose an 'M' relay that you would like to assign to that button.
For instance M0 - each time you press the button, M0 contact will close or open in your plc program
That should get you started :)
hello every body. I want to upload program from E100 HMI Beijer. I have " E - Designer " software and CAB5 programing cable. I tried with USB to...
18
3,261
Can anyone tell we where to find a simple program that demonstrates how to display a couple of messages and look at the function keys of Beijer...
4,291
Hi All Im trying to connect to E100 using CAB5 cable and e designer software but cant seem to connect. The PLC is a FX1N connected. The software...
1,775
Hi all, First post here, I hope I'm putting it in the right spot! I have an ancient Beijer E910T which went down today. Given the proximity to...
311
I am looking to upgrade a CompactLogix on V18 to an L83E on V32 which is currently using a Beijer E1151. Does anyone know if the E1151 is directly...
650
