Hi all,
Would very much appreciate some tips regarding adding a ethernet card to an e600 terminal. I have a e600 that has no ethernet card attached today.
My goal is to be able to mirror the screen on a computer which will enable me to remotely monitor the terminal.
I have:
-e600 with firmware v5.01d B304 boot: v4.03
-Mitsubishi PLC FX2N on rs424
-ethernet card IFC ETTP
-computer with e-designer 7.5 and hmi-tools installed
-rs232 straight cable
From what I have found on beijer website and forums I should be able to install the card via hmi tools and enable ftp/webserver and upload an aplet. Via iexplorer 6.0 I should then be able to mirror the terminal.
Now, before I go ahead and attempt this I have some questions...
When I try to download the program (I want a backup) from the e600-terminal via rs232 I get a message that the firmware is not compatible (v6.1 in e-designer and v5.01 on terminal). I would rather not upgrade firmware if I don't have to (if it aint broken, don't ...) Do I have to find an older version of e-designer (v6.13) to match the firmware or can I download and import the 5.01d firmware into edesigner 7.5? If so where can i get the 5.01d firmware? I can not find v6.13 in my pile of cds and it was unistalled when i installed v7.5.
I have also come across a comment that v6.x firmware was required for the applet to work on e-series but not mentioned in manual.
Thankfull for any help as I am a newbie and don't want to screw up on my first attempt
I have:
