Beijer/Mitsubishi E200 flash error
No luck with the clock chip. I tried installing one from a functional E200 with no change. Fortunately, the chip later worked in its original home.
The "Setup/IO Poll Groups" on the E1022 sounds like a good idea, but it's grayed out. Is there an easy way to enable?
Sorry, I was working on an E1032 project at the time and assumed the E1022 would be the same. Have just created a new project and it looks like the E1022 doesn't allow for I/O Poll Groups. So we are back to trying to fix your E200s, I would give Beijer a try, give them your story, tell them the Mitsi couldn't/wouldn't help and I am certain the will be able to offer advice. Otherwise you will have to go with the E1032 or equivalent to get the I/O Poll Groups. You do seem to have one of those 'banging head on wall' projects o_O.
Bryan
From E-Designer HELP
"The I/O poll interval groups are used to set individual poll intervals for each group of signals (in ms). Values 0-65535ms can be stated. If no I/O poll interval group is specified for the signal it will be polled instantaneously. The I/O poll interval group for a signal is specified using the button I/O when objects are defined. The button I/O is included in all dialogs where a signal can be stated. Not available for E1012 and E1022. See also the section"
Thank you for the offers of assistance. In the end, I was unable to revive the E200 units. The E1022 still won't work properly with my software, and I might go with a differnt HMI and PLC.:unsure:
196
Hi all, I'm hoping someone can help me with obtaining firmware files for a Beijer E700 HMI terminal. I'm looking for v4 firmware. I have an HMI...
2,808
Sadly I am in the unfortunate position to try and get an old FX0s-10MR-ES talking to a Beijer ix-T4A over serial. This is my first use of either...
1,759
I'm trying to locate V5.01 firmware .bin file for the Beijer / Mitsubishi E300. Does anyone have a copy of this they can send me? I've tried...
2,389
Hello again, I bumbed once again problem with E1000 panel. Program has been converted from E600 to E1000 series without problems. Panel...
2,444
